The zero crossing voltage is the voltage which it has to be below, in order to fire. If the voltage is about 50V, it might not fire and the peak voltage of 24VAC is just 34V, so it's unlikely to work.
Ah, thanks. I didn't realize how important that characteristic is. However, it looks like the zero crossing should work at about 30V:
I guess if you guys still think it's not a good choice 24VAC irrigation valves (solenoid, 350 mA inrush, 190 mA holding, 60 Hz) then I should find something else. I tried Digikey with
this search but it comes up with basically just 2 options: the AQH3213 or CPC1964B (SCR). Are my search parameters wrong? I choose AC, zero crossing, and 1A+ (in stock only).
The ASSR-1611 looks OK (though I'm clearly not the best judge), except it doesn't have zero crossing. Do I need that? Maybe that's why my search returns so few results. Is it rarely needed?
I need to read more about MOSFET vs SCR vs TRIAC SSRs.
