Thanks for all the answers!
With no fuses installed, there should be no continuity between the two blades of the adapter. Installing a fuse at C-D should establish continuity across the blades and the original cigarette lighter should work.
Yes it does, and to answer ArthurDent:
There is a possibility that you removed the wrong fuse from the fuse block. If you remove the fuse you previously did and check the cigarette lighter outlet and still have 12 volts, you removed the wrong fuse.
If I remove the fuse, the cigarette lighter does not work anymore, so I am confident it is the right one.
Without a fuse in A-B, there should be no continuity between any adapter blade and the blue connector. Installing a fuse should establish continuity between one blade and the blue connector (remove the C-D fuse). This blade is the HOT blade and is in common with both fuses. You could also find this by just checking the internal connections with no fuses installed.
Yes, I had played a bit with cables and the multimeter to check all the possible connections (with and without fuses installed) on my bench.
As the device is shown in the picture, I'm betting the left blade is HOT, the right leg goes to the cigarette lighter and the blue connector is the fused tap.
Indeed, I was unable to determine the hot side on the fuse box though (it is very uncomfortable to access it -- and doing that outside with a -10C temperature does not help either...).
The way to check for the right orientation is to only fit the AB fuse and leave the CD one out. Plug the TAP into the fuse block and check the voltage at the blue connector, then remove, rotate 180º, refit the TAP and check for voltage at the blue connector. One way should give you 0V and the other way should give you 12V. The orientation that gives you the 12V is the one you want.
This is the weird part -- I've already tried that, and although it works well (as expected) on the bench (both by applying 12V and by simple continuity test), once I plug it in the fuse box, I see no voltage at all irrespective of the orientation.
- Have the fuses been individually checked?
I did a continuity test with the multimeter and they work fine.
- Have you tried other fuses?
Yes, I've bought an entire new TAP holder with its corresponding fuse.
- How reliable is your "earth" point? I am very wary about using bolts - especially if there is any paint around.
Huge bolt with no paint --- I've tested it thoroughly using the cigarette lighter as reference and it seems to be good.
- When the TAP is fitted, is it twisted or under mechanical stress of any kind?
I had thought about it, therefore I have tested continuity when applying all the strain types I could think of --- seems to work well...
- Are your meter and leads in good condition? (No internal intermittents?)
Perfect conditions, and I periodically check it against a reference voltage.
My suggestion is to:
1. Check everything (yes again) fit the fuses and fit the TAP.
2. Set up your meter with solid connections to earth and the blue connector - so that you do not need to hold anything in place.
3. Push, prod, twist, wiggle, etc. around the area of the TAP and fuse block and see if anything causes meter fluctuations. If so, investigate.
On my todo list for the weekend!
When you do find out the problem - your first reaction will be relief and a sense of victory. This will soon be followed by either a "WTF!" moment if it was some obscure problem ... or a giant facepalm for something really simple you overlooked.
100% sure it is something very very dumb.... but still cannot figure it out!
Guess I'll wait for the weekend again to play a bit more with the car
Thanks again for your help -- at least now I am confident that I am not overlooking something totally trivial. I'll wait for some spare time and some sunlight, I'll try again, and I'll let you know the outcome!
Cheers,
Rob
