You could add a backwards diode on the power input, for in case if u ever connect the power wrong, or from the wrong polarity jack or whatever.
Something like a 1N400x would be fine, they all cost pennies. The idea being to allow a current in that diode, and drop the voltage across it, and not have enough voltage across any chips or caps in parallel with the PSU, that the reverse polarity blows them up...and hope it's not an ideal voltage source.
