Hello folks,
I'm building a simple step-up transformer at home for fun and learning, and am looking for some advice on measuring true power on the isolated side.
To do so, I must know the phase angle between voltage and current. So to observe current on my scope, I know I can measure the voltage across a known-ohmage resistor.
The isolated side of my xfmr is simply the secondary coil in series with a resistive load (say a power resistor). If I measure the voltage drop across this resistor using my (earth-grounded) scope, thus grounding out the circuit, will this affect the performance of the secondary coil? I'm trying to picture the current flow before and after grounding. In an isolated state, where does the current 'go'? Does it flow back into the inductor, and in doing so impede/assist the surrounding b-field? Does grounding the secondary coil reduce/increase this effect? Would this increase/reduce back-emf?
I know I could use a differential probe to measure across the resistor, but I don't have one of those.
Because of my concerns with influencing the system by grounding it, I'm considering purchasing an AC wattmeter, and letting it measure everything for me (I'm assuming they're battery-powered and isolated, not earth-grounded...). But before I do so, I wanted to ask for the advice of some experienced tinkerers. My current goal is to measure 'real power', and see what (if any) effect upon that I can have by varying properties of the core, trying different windings, etc.
And please, if I seem to be making any incorrect assumptions in this post, please feel free to offer a correction, I won't be offended. The entire purpose of this project is for personal education and enjoyment.
Edited post @21:37 GMT to clarify the question a bit
