Author Topic: Tek 465B Volts/div mechanical issue  (Read 207 times)
Offline Moose42Topic starter
  • Country: at
« on: December 26, 2024, 04:35:31 pm »
Hi folks,
 I’m posting this in the beginner section as I’m an (old) beginner when it comes to scope repair… but I imagine it is a nontrivial problem.  The Channel 2 Volts/div on my Tektronix 465B is stuck solid.  The var spins freely but the main shaft is stuck.  Peering inside, it seems that the grey plastic barrel around the shaft is fractured on the seam.  It could be an easy fix if it weren’t for the access. How does one remove and repair the volts/div mechanical internals on a 465B?  Thanks in advance!
-Moose
Online Old Printer
Re: Tek 465B Volts/div mechanical issue
« Reply #1 on: December 26, 2024, 04:54:42 pm »
Do you have the service manual?
If not, here is a link to it on the BAMA site:
https://bama.edebris.com/download/tek/465b/465b_svc.pdf
« Last Edit: December 26, 2024, 04:59:14 pm by Old Printer »
  • Country: at
« Reply #2 on: December 27, 2024, 09:56:20 am »
Hey thanks!
The following users thanked this post: Old Printer
