Short form question: Can I get different voltages by tapping into the middle of a battery pack?
I need 3.3vdc and 5vdc rails for a small toy project.
It's basically blinky leds, a single board computer and a bluetooth module.
I'm thinking of using 4 rechargeable 1.2vdc 1000mAh lion battery cells in series.
That will give me 4.8vdc, which is probably close enough to the 5vdc.
The max current draw will be about 100mA at startup for 10 seconds, and 50mA after that.
I'm thinking of getting 3.6vdc from between the 3rd and 4th cells.
But, I've never seen anything that does this.
And I've never seen any hint of this in electronics texts.
So, there must be something bad about this idea.
But, what is it?
Thanks in advance for your helpful thoughts and comments!
