IT'S ALIVE!!!
I managed to successfully install the LED and boost converter, wired ground to a PCB mounting post, and soldered to the 6V jumper on the PCB. Fired the old girl up and viola!
(See photos). I still need to mount the boost converter PCB (I'll probably use silicone, as there aren't any mounting holes on it), but it works. One weird thing, though:
When I first turned it on, it said, "Unknown signal on channel 1" and the normally horizontal straight line was a little fuzzy and wavy. It went away after doing the self-calibration, though. Any thoughts on what that might be?
So, I'm going through the manual, step by step. Got the self-calibration done, and got the probes calibrated ( I ran them thought the probe check Wizard, and they passed)
So far, so good. Looks like it might be a good working scope!
Thanks to everyone for their help. Special thanks to tautech for the suggestions on where to connect the boost converter. It made the job a lot easier.
