Author Topic: Crystal Load Capacitance calculation incorrect  (Read 204 times)
Offline FreshmanTopic starter
  • Country: in
« on: September 20, 2024, 04:18:25 am »
I am using this device (https://ww1.microchip.com/downloads/aemDocuments/documents/UNG/ProductDocuments/DataSheets/USB251xB-xBi-Data-Sheet-DS00001692.pdf)
On page 44 of the datasheet, they have given the formula to calculate the crystal load capacitance.
I have a crystal. It's datasheet mentions that it's load capacitance is 6pF and Shunt capacitance is 3pF.
And considering 3pF for CB1 and Cxtal of 6pF (mentioned in the pin capacitance table), CS1 = 3pf + 6pf = 9pf.
If I substitute CS1 in the formula,
C1 = 2*(CL - Co) - CS1
CL = 6pf
Co = 5pf
C1 = 2*(6pf - 5pf) - 9pf
C1 = 2pf - 9pf
C1 = -7pf
I am getting negative capacitor values for the load capacitances.
Am I missing something or doing incorrectly.
So, does this crystal not support this device?
Offline PGPG
Re: Crystal Load Capacitance calculation incorrect
« Reply #1 on: September 20, 2024, 09:04:00 am »
I would expect PCB track capacitance being smaller than 3pF.
You write that your crystal has Shunt C = 3pF and then use 5pF in equations. Which value is correct?
Offline Benta
« Reply #2 on: September 20, 2024, 10:14:20 am »
I think you forgot to read Note 7-1 and 7-2.
