Author Topic: Temperature of lightbulb tungsten wire  (Read 2350 times)
Offline Simon123
  • Country: si
    • Youtube channel
« on: March 11, 2014, 03:56:36 pm »
Hello!
In school we had to calculate temperatur of lb tungsten from data we collected druing measurments.
The formula we were given is R=R20(resistance at 20°c)+R20*a(temperature coeficient)*change in temperature.
I rearanged formula like this:
?T=(R-R20)/(R20*a)
Is this correct?
Offline Len
Re: Temperature of lightbulb tungsten wire
« Reply #1 on: March 11, 2014, 04:10:40 pm »
Maybe. Does "?T" mean "change in temperature"?
Offline Simon123
  • Country: si
    • Youtube channel
« Reply #2 on: March 11, 2014, 04:24:04 pm »
Yea, sorry i inserted delta symbol and it converted it into this.
Offline Len
« Reply #3 on: March 11, 2014, 04:41:39 pm »
Yes, it looks correct to me.
Offline Simon123
  • Country: si
    • Youtube channel
« Reply #4 on: March 11, 2014, 05:02:08 pm »
Ok, thanks.
Offline IanB
« Reply #5 on: March 11, 2014, 05:16:39 pm »
Given:
R = R20 + R20 · a · (T - 20)
You can factorize this:
R = R20 [ 1 + a (T - 20) ]
Do you now see a better way to rearrange it?
« Last Edit: March 11, 2014, 10:41:39 pm by IanB »
Offline NANDBlog
  • Current job: ATEX certified product design
« Reply #6 on: March 11, 2014, 10:22:24 pm »
Hint: It will be around 6000 K to match the color of the sun, unless you tweaked the voltage.
You are right, it is getting late.
« Last Edit: March 11, 2014, 11:20:02 pm by NANDBlog »
Offline Len
« Reply #7 on: March 11, 2014, 10:55:25 pm »
That turns out not to be the case. Tungsten incandescent bulbs are not the same colour as sunlight. You can see this if you turn on a light during the day.
Offline ConKbot
« Reply #8 on: March 11, 2014, 11:56:47 pm »
Traditional incandescent bulbs should be in the 2500-3000K range, and a halogen bulbs run hotter in the 3000K to 4000K range, however thats ideally, assuming the emissions are black-body, which they probably arent exactly, but it should get you in the right ballpark at least.
