Yea, sorry i inserted delta symbol and it converted it into this.
Hint: It will be around 6000 K to match the color of the sun, unless you tweaked the voltage.
Quote from: NANDBlog on March 11, 2014, 10:22:24 pmHint: It will be around 6000 K to match the color of the sun, unless you tweaked the voltage.That turns out not to be the case. Tungsten incandescent bulbs are not the same colour as sunlight. You can see this if you turn on a light during the day.
