Author Topic: Temperature sensor RS485 MODBUS RTU?  (Read 3250 times)
Offline onesixrightTopic starter
« on: November 22, 2018, 02:00:34 pm »
Hi All,
Maybe someone can shed some light on this.  TBT didn't go threw the modbus rtu protocol, maybe thats where the problem lies  :-[ Just a case of RTFM?
I have a RS485 sensor, which I hooked to to a USB / RS485 adapter. Seems to work fine, but I don't fully understand how this operates.
I connect the sensor, open an serial program, and data starts to flow. Basically it is pushed every second.
data:
T: 22.2  H: 56.1T: 22.2  H: 56.1T: 22.2  H: 55.3T: 22.2  H: 55.3T: 22.2  H: 54.7T: 22.2  H: 54.7T: 22.2  H: 54.7T: 22.2  H: 54.1
Now this I can easily parse, yet i thought I needed to pull the data out of the sensor? When I try that (pulling), i'm getting some checksum errors.
# Python 3
import minimalmodbus
instr = minimalmodbus.Instrument('/dev/tty.SLAB_USBtoUART', 1, minimalmodbus.MODE_RTU)
instr.serial.baudrate=9600
print(instr.read_register(287, 1))
# response
ValueError: Checksum error in rtu mode: '.3' instead of 'M«' . The response is: 'T: 23.3' (plain response: 'T: 23.3')
I tried changing registers, but it doesn't not seem to matter. I'm guesing the request is sent, yet since the sensor pushes on its own all gets mixed up.
Since it was a cheap sensor from eBay, of course no datasheet. So i'm a bit in the dark how to configure this. Like changing the address (want to use multiple sensors on the bus).
Maybe it's possible to change the mode, but without a proper databasheet it is hard. Or is this all speced in the modbus rtru protocol?
Anybody that knows whats going on?
Thanks!
Sensor:
https://www.ebay.com/itm/RS485-Temperature-and-Humidity-Transmitter-Sensor-High-Precision-Monitor/123234164113?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Offline capt bullshot
Re: Temperature sensor RS485 MODBUS RTU?
« Reply #1 on: November 22, 2018, 02:31:04 pm »
The data you receive from the sensor clearly isn't modbus. It's just some kind of readable ASCII.
Better go ask the seller for some dokumentation how to switch the thing to Modbus mode and which registers to read / write (Modbus is all about registers, but there's no standard how to use the registers).
« Reply #2 on: November 22, 2018, 03:09:04 pm »
WILCO.
Thanks, yeah I got this feeling something is not right. So modbus (rtu) would not push on its own data right?
« Reply #3 on: November 22, 2018, 04:13:11 pm »
No. Modbus is a strict master/slave protocol, the master addresses a particular slave and asks for a register content, then the slave answers / the master writes a register, the slave confirms.
« Reply #4 on: November 22, 2018, 04:17:38 pm »
Thanks, thats what I thought.
He did write:
Automatic output, connection RS485 through serial debugging tool will automatically output temperature and humidity.
« Reply #5 on: November 23, 2018, 07:55:55 am »
Well found same sensor on banggood, they had some documentation that I could use.
All works now.
Offline bingo600
« Reply #6 on: November 25, 2018, 07:24:53 am »
Link ??
/Bingo
« Reply #7 on: November 25, 2018, 10:15:14 am »
Link ??
/Bingo
Same sensor:
https://www.banggood.com/Modbus-RS485-Temperature-and-Humidity-Transmitter-Sensor-High-Precision-Monitoring-p-1159961.html?gmcCountry=CZ&currency=CZK&utm_source=googleshopping&utm_medium=cpc_elc&utm_content=zouzou&utm_campaign=pla-cz-ele-cs-pc&gclid=EAIaIQobChMI86fW-aTv3gIVSsKyCh1_KwM3EAQYAyABEgKD0vD_BwE&cur_warehouse=CN
Link to the files:
http://files.banggood.com/2018/04/software-and-protocol.zip
The short:
- if you hookup to serial terminal program, its start spitting out the data in ASCII.
- when you use with modbus protocol (as intended) it works: to read use input_registers (reg 0 = temp, 1 = humidity)
- change slave address: disconnect all sensors but the one you want to change and do a write_register with address "0"
- change slave id is stored (also after power loss)
Tested with pymodbus (working)
I have two sensors There is a little bit of a difference between the 2.
Query sensor on address #1
It's 22.7C with 61.7% RH
Query sensor on address #2
It's 23.0C with 54.8% RH
