BJTs are current-driven - no base-emitter current equals no current whatsoever... And base is low impedance. So why is it that in most circuits I see pull-up or pull-down resistors on BJT bases? I thought the only time you need a pull-up or pull-down is if you have a high impedance, voltage-driven input to prevent excessive weirdness from happening... But if you left a BJT base dangling, it would just cut current and close the transistor...
...or wouldn't it?
Additionally, because they are
actually voltage-driven as mentioned above, they can remain turned on for a short period of time by charge held in the base, just like a MOSFET (only not as dramatic). A pull-down resistor can help them turn off faster, and the effect of that resistor setting a lower bias point even in saturated switching applications can limit the amount of charge put into the base in the first place.
