Author Topic: Test Equipment for current supply and voltage measurement  (Read 1733 times)
Offline JamesHowlett
« on: October 09, 2014, 07:16:37 pm »
Hello,
I have a simple question, which can be answered almost everybody in the forum. I want to supply a dc current to a material from two contact and measure the voltage from another two contact, sort of an I-V measurement. What sort of equipment do I need for it?
I made my small research and I found couple of alternatives such as, keithley 2400 SMU and adjustable power supplies form keithley and Agilent. One is a SMU and the others are power supplies and as far as my knowledge concerned, I should say that I am confused a little bit.
As the requirement:
setting a current value and increasing the value with steps until the end value with defined steps
measuring the voltage simultaneously with the same equipment
logging the data with the pc to calculate the resistance of the material
I know there are lots of answers depends on the precision and the voltage-current ranges, but I ask to have an rough idea about the test equipment.
Cheers!
Physics Engineer, Materials Scientist, PhD candidate on battery research, Electronic Hobbyist...
Offline w2aew
    • My YouTube Channel
Re: Test Equipment for current supply and voltage measurement
« Reply #1 on: October 10, 2014, 02:58:16 am »
Hello,
As the requirement:
Cheers!
An SMU is the simplest way to do this, because it allows you to source a specific current or voltage, and measure the resulting voltage or current. You can accomplish some of the same functions with a current limited power supply and DMM, but you have to set it all up manually and you might not be able to achieve 4 quadrant operation. A SMU like the 2400, 2450, etc can do this easily, as well as sweep the stimulus to generate an IV curve etc.
FAE for Tektronix
« Reply #2 on: October 10, 2014, 08:14:30 pm »
Hello,
As the requirement:
Cheers!
Thanks a lot! Now I should find a budget SMU, Keithley is relatively expensive, but I will call the companies on Monday anyway to see whether they can offer something less expensive and more application specific(voltage and current limits wise).
just out of curiosity, isn't there any voltage or current source which can be programmed to scan a current range?
Regards
