After being so impressed with HP 34401A DMM I decided to acquire second bench PSU from same HP lineage. With wider voltage range and perhaps more PRO hw than my current OWON clone (also seen on attached pic).
Potential issue - while it works across all ranges and passes trough "hold [Display Limit] button while powering unit up" self test routine I'm concerned about 6 mV voltage while output is off. As seen on attached pic.
Another somewhat related behavior. When I'm doing same hold button power up self test routine it puts out 1V and that stays after self test is done. However 1V goes away after I turn output On-Off and it settles on 6mV. Hm...
Also note to myself - Think twice before buying used PSU-s again. I had to deal with a lot of smelly dust bunnies grown in heavy smokers lab In Japan. Also fan is rattling a little annoyingly. I wonder if Noctua is making HP compatible replacement fans...
