Author Topic: Test probes recommendation  (Read 1365 times)
Offline UniTopic starter
« on: October 21, 2018, 09:23:26 am »
Hi guys
I have a frequency counter (HP5315a) but no probes.
Im going to use this for calibration purposes of audio gear only (synthesizers, drum machines, etc etc)
I’m a bit confused as to which probes to use.
Would anyone recommend something ?
Can I use this one maybe ?
https://www.ebay.com/itm/Hantek-PP-150-X1-X10-100MHz-Oscilloscope-Clip-Passive-Probe-BNC-Port-Probe/123394470806?pageci=4d2f85c2-47f1-4233-9f91-82b9c20fa620&epid=1958370226
Offline MiDi
  • Country: ua
Re: Test probes recommendation
« Reply #1 on: October 21, 2018, 09:43:57 pm »
You should be fine with bnc to alligator-clips for audio range, no need for an oscilloscope probe for high bandwidth.
Offline tkamiya
« Reply #2 on: October 22, 2018, 04:14:34 am »
I agree with alligator clips for audio use.  You can also have an unterminated BNC connector/cable and solder when necessary.  Probes are usually not used for frequency counters.
« Reply #3 on: October 22, 2018, 10:57:45 am »
I see :) Thanks for the replies!
Offline rdl
« Reply #4 on: October 22, 2018, 04:35:02 pm »
This is basically the same as what I use most of the time. I got all mine separately though, and from different sources, so I can't vouch for the quality of these.
https://www.ebay.com/itm/BNC-to-Alligator-Clips-BNC-to-Mini-Test-Clips-BNC-to-BNC-Cable-Oscilloscope-Test/113322032324
« Reply #5 on: October 22, 2018, 05:54:07 pm »
