Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
test results
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: test results (Read 689 times)
m3vuv
Super Contributor
Country:
test results
on:
November 23, 2021, 05:52:26 am »
hi all,can anyone explain these readings i get on my component tester,its testing an old pnp germainium,im wondering about leakage,i assume the uf is the junction diode drop,and the B is hfe,not sure of the others tho.
Logged
m3vuv
Super Contributor
Country:
Re: test results
Reply #1 on:
November 23, 2021, 05:54:06 am »
and another pic
Logged
ataradov
Super Contributor
Country:
Re: test results
Reply #2 on:
November 23, 2021, 06:07:00 am »
It is a PNP transistor. Emitter, Base and Collector pins are 1, 2 and 3.
Transistors Beta (Hfe) = 93, forward voltage 203 mV.
ICEO (not 0) is usually a collector-emitter leakage current with the base open.
Last Edit: November 23, 2021, 06:09:36 am by ataradov
Logged
Alex
m3vuv
m3vuv
Super Contributor
Country:
Re: test results
Reply #3 on:
November 23, 2021, 06:51:23 am »
would you say that is bad then as it leaks,what sort of leakage current is normal for a working transistor then?
Logged
ataradov
Super Contributor
Country:
Re: test results
Reply #4 on:
November 23, 2021, 07:06:16 am »
10 uA is perfectly fine. I doubt that thing can meaningfully measure currents that low, so I would discard that measurement. Just treat it as "OK".
Logged
Alex
m3vuv
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
test results
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
