Hello, I am measuring the triac BT136 and some other triacs in order to find a way to test them with multimeter. If I measure the triac between the Teminal 1 (Positive lead of multimeter with the Gate pin together) and Teminal 2 (negative lead of multimeter) the multimeter doesn't show anything but if I reverse the multimeter leads it measures ok. I can't understand hy happens this because the triac is a bidirectional component. I have made a diagram in the below picture of how and what I measured. Does anyone knows why this is happend?
