Well you're getting better at it
. Practice makes perfect.
I suspect that there are some errors, yes. Incuding passive component values would help identify these better.
So what do we know so far?
- The circuit has an open drain output.
- The Mosfet is being driven by a non-inverting amplifier circuit. R7 is there to prevent oscillation of the Opamp / mosfet gate.
- Pin 1 looks like ground, but so does Pin 4 as C3 look is a decoupling capacitor for the opamp supply.
- Pin 2 is the analogue input with R8 and R9 forming an input potential divider.
- Pin 3 is your positive supply for the opamp.
- R5 and C2 look right as the opamp feedback path
- Really not sure that the bottom of the schematic is correct (R2 - including wiper connection, R3, R4, R10 and C1).
- It's possible that one of the Resistors (R4?) might be being used as a current sense resistor, you need to add values to make this clear.
It's unlikely that the opamp is there just to buffer the mosfet gate. My guess, when the schematic is clearer is a set of variable current sources (assuming that one of the resistors is in series with the Mosfet source).
Keep at it.
