Hi, my coffee machine won't switch on...😲😲😲I've dismantled it and have possibly found the culprit.But I need help identifying the value of the capacitor/resistor???Please help, I need my coffee...Photo attached...
Orange Black Red Gold 3mH?Going to also want to check the diodes around that area as well.
Not powering onNo LEDsDraw 1VA (<<1W)PCB labels: "Nespresso Lattissima Switching" "05/07/2010" "Procond Elettronica"When removing PCB, labelled wires as F1, F2, F3, F7 etcPIC18LF2520-I/SO - only getting 1.8V for power pinsUses LNK364GN (Power Integrations) chipR55 = 47R 3W 5% fusible resistor - open circuitL1 = 1000uH (1mH brown black red gold) measured 1.6uH 1.6R and signs of damageC1/C3 = 4.7uF 400V Nippon Chemicon KMG Series 105C (EKMG401ELL4R7MJ16S) measure OK & 4R ESRReplaced- L1 with Bourns RLB0913-102K (1mH 350mA) slightly too big to fit between caps- R55 with 2 x 100R 2W Ohmite resistors (parallel)Still didn't power on - and the 100R resistors are now open circuitInternal short in LNK364Ordered from RS- LNK364GN- Vishay 47R 3W AC03 Fusible Safety Resistor- Epcos B82144A 1mH 200mA 3.8RDC Axial Inductor (bigger than old one)Fixed!
