Hi, im planning to make a automated battery charge/discharge cycling tester for AA ni-mh cells.
I wanted to test a whole bunch of ni-mh cells and see which one will hold more of their original capacity after a certain amount of charge cycles. (e.g 1000 like it says on the packaging)
I've whipped up a simple circuit to do constant current charging and constant resistance discharge. (see attached schematic)
The only thing that bothers me is the PNP transistor that's configured as a constant current source.
Is there any easy way to use a NPN transistor as a high side constant current source?
