Author Topic: Differential probe for HANTEK oscilloscope  (Read 2053 times)
Offline BondguyTopic starter
« on: November 15, 2016, 09:45:19 am »
Hey guys,
Can anyone recommend a differential probe for Hantek scope ( DSO5202B )  -  I am not sure if a diff. probe can be used with different scopes or a probe can be used ONLY  with a particular scope. Does anyone know?
Online BravoV
  • +++ ATH1
Re: Differential probe for HANTEK oscilloscope
« Reply #1 on: November 15, 2016, 09:51:42 am »
Budget ?
Offline tggzzz
« Reply #2 on: November 15, 2016, 10:16:48 am »
It rather depends on the signals you want to examine. State the context of your problem, not just your presupposed solution.
There is just a little bit of difference between looking at a 500V AC signal where neither side is earth referenced, vs looking at a 1V LVDS signal between two ICs.
Offline tautech
« Reply #3 on: November 15, 2016, 11:23:44 am »
Pintek DP-25 is about the cheapest new option, can be used on any 1M \$\Omega\$ BNC input scope.
