Author Topic: Testing continuity on an AC powered piezo-electric unit  (Read 864 times)
Offline edy
    • DevHackMod Channel
« on: August 30, 2014, 06:59:31 pm »
Hi folk,
I have a piezo-electric tool that has 2 wires going to it (red and green) from what I presume to be the signal transducer or generator unit that powers it. The tool unplugs from the cable with 2 wires. It wasn't working so I thought the cable must have a broken wire so I thought I would use my continuity tester on the multimeter to check it out.
To my surprise, probing the green and red wires at the same time I had continuity. Obviously this would make no sense if it was a DC supply as it mean they were shorted to one another. But somehow this is happening in this AC supply and I am trying to understand how I can have continuity between both leads heading to the piezo-electric tool. Both green and red leads are somehow connected inside the generator or shorted in some way, yet both are necessary to power the tool.
I'm thinking the green/red wires form a continuous loop that is electrically isolated in the power supply but that runs through a transformer. So I can get red/green continuity and the AC transformer drives or oscillates the polarity which causes the piezo-electric to vibrate.
« Last Edit: August 30, 2014, 07:10:26 pm by edy »
YouTube: www.devhackmod.com LBRY: https://lbry.tv/@winegaming:b
Online Zero999
  • 0999
Re: Testing continuity on an AC powered piezo-electric unit
« Reply #1 on: August 31, 2014, 09:47:17 pm »
More information is required.
A piezo transducer is capacitive so should normally read open circuit but it probably isn't just a transducer.
