I would put it this way
Continuity is the resistive point below which, the circuit does not impede it's intended function.
For example, power earth continuity would be defined as a resistance where the fault current would not create a hazardous potential difference between the fault and ground.
Electrical continuity would be a resistance that at a certain current would not create a significant voltage drop between the source and the load or a resistance that would not dissipate enough power to cause harm to the medium carrying that current
In other words, it depends...
