Author Topic: testing electrical continuity  (Read 784 times)
Offline jeroen79
« on: October 04, 2015, 11:21:30 pm »
How exactly is electrical continuity defined?
Ideally I would say 0 ? but .1 ? can be considered continuous as well.
Even 1 k? and 1 M? conduct current but I wouldn't consider them 'continous'.
And if you increase the voltage enough things like diodes will suddenly conduct.
What definition should I use when designing a continuitytester?
Resistance less than x ?? Test below y V?
Offline RobertHolcombe
Re: testing electrical continuity
« Reply #1 on: October 05, 2015, 12:09:53 am »
Continuity implies that there is a continuous path (circuit) for current to flow - the resistance threshold would depend on the DUT. General purpose continuity testers are aimed at testing relatively low resistance because the general use case is testing interconnects
Online AlfBaz
« Reply #2 on: October 05, 2015, 12:18:54 am »
I would put it this way
Continuity is the resistive point below which, the circuit does not impede it's intended function.
For example, power earth continuity would be defined as a resistance where the fault current would not create a hazardous potential difference between the fault and ground.
Electrical continuity would be a resistance that at a certain current would not create a significant voltage drop between the source and the load or a resistance that would not dissipate enough power to cause harm to the medium carrying that current
In other words, it depends...
