Author Topic: Testing heating element  (Read 1237 times)
Offline manubaliTopic starter
« on: September 08, 2018, 04:48:14 am »
Hi, i am trying to repair dry herb vaporizer for  my friend. I suspect its heating element is faulty as It works fine when element is disconnected and didn't work when its connected.
I tried to measure resistance between its terminals and it shows 0 ohms.
Is there any other way to test it?
Element is connected to drain terminal of p cahnnel mosfet and element, drain side of mosfet are shorted to ground.
Offline james_s
Re: Testing heating element
« Reply #1 on: September 08, 2018, 04:53:36 am »
What voltage does it run from? If it's low voltage then it may read zero ohms on a multimeter that doesn't have a low ohms range. A heating element is nothing more than a resistor, the typical failure mode is they burn out and go open circuit. What do you mean by "doesn't work"? Does it blow the fuse? Shut off?
« Reply #2 on: September 08, 2018, 05:26:54 am »
It runs with single 18650 battery around 3.7 volts.
It shuts off after few seconds when power button is pressed.
It was dropped and it stopped
Offline DTJ
« Reply #3 on: September 08, 2018, 06:57:20 am »
A dry herb vaporizer running of a 18650?
Is it like an electronic bong?
Offline james_s
« Reply #4 on: September 08, 2018, 07:19:13 am »
For such a low voltage I would expect the heating element resistance to read close to zero. Are you sure it's not just a dead battery? Is the charging circuit actually charging it?
« Reply #5 on: September 08, 2018, 12:49:50 pm »
Yes its charging fine, i even tried hooking it to bench power supply.
It have thermistor attached to heating element, i think heater turns on when temperature is low and when micro senses overheating, it just turns it off, and now i think somehow after drop the thermistor got faulty and now its giving false reading thats causing it to trip.
I checked the heater by applying around 4 volts and it heats fine.
« Reply #6 on: September 08, 2018, 12:52:48 pm »
Its called g pro vaporizer, its same as vape pen but it have small chamber to put herb in it
Offline james_s
« Reply #7 on: September 08, 2018, 05:09:40 pm »
The thermistor could easily have been damaged by the drop. You can test it by measuring the resistance, it should go either up or down as you heat it.
