Was watching this video.
In the picture below, the larger laptop power brick is my power source for the DP30V5A DC to DC converter.
From the brick I am getting a ground so that the metal case is grounded, the front lower left black binding post is on the same ground.
From the video Dave was taking about using brick power supplies that have a ground, and that the common could be attached to ground. ( trying to say this in a way that will make sense hopefully)
When I check the black ground on the lower right to the common or - below the red binding post my meter reads .947 K ohms with it powered.
Does this mean that the power supply is not floating?
When I use it to power up circuits where do I put the ground from the Oscilloscope. A. the black ground binding post or the black negative post.
Just built this would like to not blowup my only power supply and Oscilloscope.
