Simple test is place finger on opamp with power on. Finger not hot= possibly working. Finger hot=possibly dead. Finger has imprint of part number burnt into it=Dead Jim.
If possibly working or possibly not check supply voltages. As it is a quad opamp check each stage, +input voltage, - input voltage and output. + & - should be close to each other ( less than 10mV) and output should be somewhere between V+ less a volt and V- plus a little. If they are at rails then Dead Jim. Use meter with high input impedance, if inputs have resistors under around 20k then a 10M meter will do.
As it is a jellybean opamp easiest to do if it is Dead Jim or it seems suspect is to replace with another. If it is a DIP part and you just want to see cut the leads off flush with package plastic and slip the new one temporarily into the socket now there to check quickly. Then you can do the desolder of pins and solder in new or just solder the stubs to the new if you are in a hurry. Done that on boards where you could not get to the bottom at all unless you started at one end of the board and removed a line of DIP packages till you got to the one you wanted and had a vapour phase reflow bath to redo all the solder paste to put them all back.
