I made a simple filter cap "tester". It's just a 100uF 500V capacitance with crocodile clips for positive and negative. I use it to find 100hz buzz from bad filter caps, paralleling one cap at a time until the buzz goes away... then I have found the bad cap that needs replacing.
When done I discharge the "tester" through a resistor.
I usually have the amp on while testing and change the positive lead from cap to cap. Each time I clip the positive lead to a cap I get a tiny arc.
Is there a way to not have this happen? I find it startles/scares me even though I know it is going to happen.
Would paralleling a resistor work?
