This thread is somehow related with dummy constant current load like Dave did, and while reading lots of mosfet datasheets, my eyes spotted interesting fact that at low vds condition, most common "switching mosfets" when it's VDS is at pretty low say below 1 volt, the ability to conduct current is quite low compared to higher voltage say > 5 volt, even the gate already driven like at 10 volt.
Take the MTP3055V as the example, this exact mosfet is also used by Dave at his constant dummy load.
When VDS at 0.5 volt, the max current is only at around < 6 Amp, also this chart is where Tj at 25 C, and aware that at higher Tj, this number will be even lower.
/?action=dlattach;attach=24555;image)
Aware of other special type linear mosfet like the one made by IXYS, which has an impressive current capability even at very low vds, the chart below from IXTK200N10L2 shows the capability with Tj at 125 C
. Compared to above cheap MTP3055V, its like night and day.
/?action=dlattach;attach=24557;image)
Assuming I have lots of spare MTP3055V or other common switching mosfets lying around, and don't feel like to make a dent in my pocket to order the IXTK200N10L2 above at $25 a pop
Now questions :
- If I want to use a common mosfet for disspating at high current say like 10 Amps at 0.5 Volt source, can I use MTP3055V or other common cheap switching mosfet in parallel to solve with this single mosfet limitation ?
- How about the opamp that is driving the gates of parallel mosfets or even the overall circuit ? Does it need major modification ? and how exactly ?
TIA
PS :
Aware of the potential issues when common switching mosfet used in linear mode in dissipating high energy, made a thread for it while ago here ->
CLICK, but please ignore this issue for a while in this thread.
