Hi
Looking for ideas and this has always been a very helpful forum.
I want integrate a 433Mhz siren in to Arduino (specifically the Arduino present on the BeagleBone cape that ships with the Ninja Block) so as far as I can tell this is all about rc-switch (warning big phone cam images):
https://dl.dropbox.com/u/2436853/alarm.jpghttps://dl.dropboxusercontent.com/u/2436853/alarm2.jpgThere is an atmega48v on there, the RX says 9931A on the PCB and has a cd4069ubm hex inverter being used I assume for the receiver.
Basically I have the remote and the siren, the remote actuates the siren, rc-switch sees the button press as a 24bit code, I can see it but when I try to use the code to actuate the siren using rc-switch nothing happens, I believe RX and TX are implemented in different parts of rc-switch and so there could be stuff that RX OK but that doesn't TX properly.
I want to decode what's going on both to get a better understanding of electronics and to get this flipping siren working. I have no idea where to start, I have access to a scope, logic analyzer and sdr (I would be a beginner on all of them) as well as lots of Arduino boards and breakouts including 433Mhz, can somebody point me in the right direction please?
Thanks.
Rich
