Electronics => Beginners => Topic started by: rthorntn on October 15, 2013, 06:04:18 am
Title: The best way to decipher a wireless protocol
Post by: rthorntn on October 15, 2013, 06:04:18 am
Hi
Looking for ideas and this has always been a very helpful forum.
I want integrate a 433Mhz siren in to Arduino (specifically the Arduino present on the BeagleBone cape that ships with the Ninja Block) so as far as I can tell this is all about rc-switch (warning big phone cam images):
https://dl.dropbox.com/u/2436853/alarm.jpg
https://dl.dropboxusercontent.com/u/2436853/alarm2.jpg
There is an atmega48v on there, the RX says 9931A on the PCB and has a cd4069ubm hex inverter being used I assume for the receiver.
Basically I have the remote and the siren, the remote actuates the siren, rc-switch sees the button press as a 24bit code, I can see it but when I try to use the code to actuate the siren using rc-switch nothing happens, I believe RX and TX are implemented in different parts of rc-switch and so there could be stuff that RX OK but that doesn't TX properly.
I want to decode what's going on both to get a better understanding of electronics and to get this flipping siren working.  I have no idea where to start, I have access to a scope, logic analyzer and sdr (I would be a beginner on all of them) as well as lots of Arduino boards and breakouts including 433Mhz, can somebody point me in the right direction please?
Thanks.
Rich
Title: Re: The best way to decipher a wireless protocol
Post by: adam1213 on October 15, 2013, 07:40:37 am
How do you know that the "rc-switch sees the button press as a 24bit code" - is this in the specifications or did you measure this.
A good way to start is by looking at the requirements for the siren:
Post by: rthorntn on October 15, 2013, 08:13:13 am
Thanks adam1213!
The ninja block sees the remote button press and it has a UI that shows the code but the actuate function using the observed code does not work.
The siren does have a learn button.
I didn't think about some sort of anti-sniffing technique.
How would I record the press, I could build an arduino with 433mhz radio and probe the radio pins, would a scope or logic analyzer be better, I could also setup the SDR and sniff at 433mhz watching the gnu radio scope...?
Thanks again.
Richard
Post by: adam1213 on October 15, 2013, 11:53:09 am
What code shows up / at least the start of the code?
I suggest you probe a 433mhz receiver and look at:
Setup:
433mhz receiver - connect to power, probe output pin. ** note: you can use the receiver that is part of the ninjablock and probe it.
