Author Topic: The heck is this?!?  (Read 2263 times)
Offline GadgetBoyTopic starter
The heck is this?!?
« on: October 20, 2018, 12:34:15 am »
Pinkish resistor with red, red, gold, gold, white (or vice versa - doesn't make sense either way).
Any thoughts?
Sent from my ONEPLUS A3000 using Tapatalk
Offline Housedad
Re: The heck is this?!?
« Reply #1 on: October 20, 2018, 01:03:09 am »
I ddon't know a lot, but my best first guess would be some kind of old axial lead capacitor.  Paper wound.   But the board says R10.  Makes no sense.
If you have a ESR meter you may want to try it and then see what the DC resistance  (and continuity) of the part to help find out.
What is this in?
« Last Edit: October 20, 2018, 01:05:48 am by Housedad »
At least I'm still older than my test equipment
Offline tooki
« Reply #2 on: October 20, 2018, 01:10:55 am »
I think the pink denotes a fusible resistor. (As in, not all fusible resistors are pink, but if a resistor is pink, there's a decent chance it's fusible.)
« Last Edit: October 20, 2018, 01:18:17 am by tooki »
The following users thanked this post: Housedad
Offline floobydust
« Reply #3 on: October 20, 2018, 01:15:29 am »
The first four bands are the usual IEC: red red gold gold = 2 2 x0.1 ±5% gives 2R2 ±5%.
The fifth band is open season, unfortunately (resistor) manufacturer specific.
These have a safety function because they burn up when something else fails short circuit.
It would be a flame-proof fusible resistor. But I am not sure who made it, i.e. Yageo, KOA, Welwyn, TT, Futaba etc.
Fifth band:
White: fusible
Gold: miniature fusible (usually with pink body)
Yellow: "constant voltage fusibility"
Black: sometimes wirewound fusible resistor, but I see film types too
Violet: Vishay NFR25H
Some series use coloured fifth band to denote fusibility overload rating (4x,8x,64x).
The following users thanked this post: bitwelder, Housedad
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #4 on: October 20, 2018, 01:26:08 am »
Or use the brute force method - unsolder one end and get to it with a DMM ...  :popcorn:
Offline Housedad
« Reply #5 on: October 20, 2018, 01:27:17 am »
Oh, I see what you mean.  The 5th white band is confusing, leading to believe it is a 5 band when it is only meaningful to the manufacturer and not standard code?
So a 4 band with a junk band at the end.  Sounds like a bad concert.
I'll always call them "bad concert" resistors after this.
« Last Edit: October 20, 2018, 01:30:26 am by Housedad »
Offline drussell
  • Hardcore Geek
« Reply #6 on: October 20, 2018, 02:06:40 am »
Various manufacturers use the lacquer color on the body to denote different series / material technology but there is no industry standard.  Ditto for things like that fifth band, it often denotes special series or characteristics / options.  You would need to know the manufacturer to be able to decypher a particular code with absolute accuracy.
For example, Yaego FKN and PNP series both have green bodies, in this case denoting Wirewound construction.  The PNP series has a violet 5th band, denoting "High Power, Ultra Miniature" type while the FKN series has a white 5th band, denoting "Fusible & Flame Proof, Normal and Mini."  In the case of the FMP series, the pink body denotes Metal Film construction, etc. etc.
There are a virtually limitless number of permutations and combinations even among the various series available from a given manufacturer.  For example, in addition to the note "The resistors are coated with layers of green color flame-proof lacquer," the FKN series datasheet shows:
Datasheets: Yaego FKN series, Yaego PNP series, Yaego FMP series
The following users thanked this post: bitwelder, tooki, Housedad
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: October 20, 2018, 03:39:15 pm »
Other evidence aside, it's placed suspiciously close to -- probably in series with, a quick look at the solder side will prove this -- an AC line, which if that's mains, and there's no fuse in sight... doing double duty for inrush limiting and fusing is not at all a bad guess.
Seven Transistor Labs, LLC
