Author Topic: Thermal Resistance  (Read 1328 times)
Offline jose347Topic starter
  • Country: pr
Thermal Resistance
« on: October 11, 2018, 08:51:25 pm »
thermal resistance (oC/W) how does it works?
for the junction to case which will be better a higher value or a lower value?
Thanks
Online RoGeorge
Re: Thermal Resistance
« Reply #1 on: October 11, 2018, 09:09:03 pm »
Thermal resistance will tell how much the internal temperature of the transistor increases for each watt.
Example: a transistor with R = 10*C/W, at 5W will raise the internal temperature with 50*C. If in the room are 30*C, the internal temperature of the transistor will be 30 + 50 = 80*C. For the same transistor but at 15W, the total temperature will be 30 + 150 = 180*C (=356*F). This will probably melt the transistor and destroy it.
A lower value for the thermal resistance is better for the transistor.
Offline Brumby
« Reply #2 on: October 12, 2018, 10:51:06 am »
It's an older video of Dave's, but the principles have not changed...
You basically take the ambient air temperature, work out ALL the thermal resistance components from the air to the working zone of the component (the silicon die for ICs, transistors and the like) and add them up.  With this figure and the power your component is dissipating, you can work out the temperature that the die will get to when it is working at that power level.  You then look this temperature up in the component's datasheet and see if it will survive.
Understand that you must keep it under the maximum temperature, but getting that temperature down further will increase the reliability - and the life - of that component.
« Last Edit: October 12, 2018, 10:58:07 am by Brumby »
  • Country: pr
« Reply #3 on: October 15, 2018, 06:19:51 pm »
Thanks All
