Well Hero999, thank you for not giving up on me. I will recheck the datasheets. I believe the component values are correct, I actually de-soldered all the components and measure all the resistors with lcr meter. And I was also able to read all the values for diodes and caps. The transformer is still unknown, no markings. I did apply an ac voltage to it to figure out the primary coil and I checked the impedance. That's why this circuit is giving me a headache, looks simple but can't make sense of it. I even probed it all with oscilloscope very carefully not to ground the high voltages with my probe gnd. Anyone else here sees anything wrong? Or suggestions?
