Author Topic: Threaded alligator clips for insulation tester probes  (Read 521 times)
Offline malagas_on_fireTopic starter
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« on: September 14, 2019, 09:06:10 pm »
Hi
I bought recently some uni-t probes with screwable M4 in order to add on threaded allligator clips to serve as spare probes for insulation  tester . However i couldn't find properly identical to the original one which is also uni-t .
 Both have no markings of the model.
The best aproach i've got was this "based" fluke AC175:
https://ebay.us/CGG1HK
But either i found the same model on other sellers as snap-on only or threaded snap on.
The uni-t model for the threaded one is UT-C05A (M4) but didn't find a good price or a local distributor.
https://www.uni-trend.com/html/product/qita/ut-c_alligator_clips/UT-C05A.html
Are there better alternatives to this threaded alligator clips which are compliant for insulation tester up to 1000V? Insulation Tester Model is uni-t ut 501A.
« Last Edit: September 14, 2019, 09:08:43 pm by malagas_on_fire »
If one can make knowledge flow than it will go from negative to positve , for real
