Hello,
I Just need to get my facts straight on the name and the job of each type of capacitor.
Bypass capacitors bypass the power supply to absorb positive voltage spikes and supply voltage for when you have a negative voltage spike.
Decoupling capacitors remove the ac from a signal.
Coupling capacitors remove dc. Like dc offset or whatever.
Filtering capacitors remove noise on the signal.
Smoothing capacitors help get flat dc and usally found either side of voltage regulators.
Bulk capacitors are like bypass capacitors but bigger and are found in the power supply and are used to charge up the bypass capacitors.
Storage capacitors are used to temporary power when you remove a coin cell battery from an RTC circuit or for timing like in the 555 timers.
Suppression capacitors come in x and y class and are used to reduce EMI.
Have i got all the facts right? Am i missing anything or any other type? Does one type of capacitor have multiple names? etc are couple and decoupling caps types of filter caps?
The thing is. If im right about the names and facts, people must be getting it confused or wrong because people always call everything a decoupling capacitors when they really mean bypass capacitors and visa versa. Also people mix up filter and smoothing all the time. I understand that capacitors can do both but if its either side of a regualtor it should be called a smoothing capacitor because thats its main purpose. Its really annoying. Same with people calling it bypass or decoupling when talking about removing noise from a signal. They should call it filtering.
This is all really hard terminology for a young player like me haha.
Thanks so much,
Will Smith
