Author Topic: What resistor is this?  (Read 4516 times)
Offline laserpon3Topic starter
« on: December 07, 2012, 04:12:01 am »
I am familiar with resistors but.
On dave's video of the lab power supply design part 3 he uses some weird big white resistors. [0:38]
https://www.youtube.com/watch?feature=player_detailpage&v=8-qar5vgnbc#t=38s
I have also seen this resistors being used in another lab power supply making video:
What type of resistor is this?
I can't seem to find them or find a proper place to buy them (as I don't know what they are).
Why are these used for dummy load instead of the more common resistor types? less heat? more durability? higher resistance?
From what I believe, dummy loads are a lot of resistors connected to eachother. I'm not sure, but searching dummy load resistor doesn't give me anything looking close to this.
« Last Edit: December 07, 2012, 04:19:28 am by laserpon3 »
Online Psi
Re: What resistor is this?
« Reply #1 on: December 07, 2012, 04:29:11 am »
It's a "ceramic wirewound resistor". They're the next step up from a normal resistor in terms of power handling.
The small white ones start at around 5W and some of the larger ones are 40W+
Digikey have them in the  "Through Hole Resistors" section.
Just parametric sort based on above 5W and you will find lots of them.
eg http://www.digikey.co.nz/product-detail/en/SQP20AJB-1R/SQP20AJB-1R-ND/1680006
More common? those kind of resistor are really common.
There are other types as well. Like these more expensive mountable ones, some of which can handle 100W if mounted properly.
« Last Edit: December 07, 2012, 04:48:31 am by Psi »
Offline nadona
« Reply #2 on: December 07, 2012, 04:31:03 am »
I think they call it cement resistor. Maybe you get the clue by reading this paper. http://www.yageo.com/documents/recent/Leaded-R_PSP_2011.pdf
Ha-ha-ha. That's good, too!
« Reply #3 on: December 07, 2012, 04:40:40 am »
Thanks guys!
This answered the question for me! :)
« Reply #4 on: December 07, 2012, 04:47:58 am »
Wire wound resistors in a ceramic boat. Common at high power, as the case is an insulator even when red hot. Most round wirewound ones with a dip coat are conductive through the coating when they get hot enough.
Offline T4P
  • Country: sg
    • T4P
« Reply #5 on: December 07, 2012, 05:47:47 pm »
And there are massive/powerful wirewound ones that are green in colour and you can see the wound wire on the substrate! But they are quite dangerous ... exposed wire, who wants some of that?
Usually they look like that
But ...
sometimes they come like that
Offline Short Circuit
    • White Bream electronics R&D
« Reply #6 on: December 07, 2012, 06:01:12 pm »
... But they are quite dangerous ... exposed wire, who wants some of that?
Most resistors have exposed wires... Big ones no different than your standard 1/4W PCB resistors  ;D
And you want to shield them from unintended touching anyway, these things can get hot, very hot.
Operating temperature range up to 225 degrees (TE range), much hotter during short term overload condition.
You don't want people to touch that by accident.
« Reply #7 on: December 07, 2012, 07:57:38 pm »
The conductivity is a problem if it is mounted in a metal clamp and it gets hot, which then causes a leakage to the clamp of the resistor voltage. It is possible to have enough current flow to make it go into thermal runaway.
Online IanB
« Reply #8 on: December 07, 2012, 11:37:25 pm »
If you are in the USA (you have no location in your profile) then go have a look in RadioShack or maybe Fry's. You will find resistors looking just like that in power ratings of 5 W, 10 W or 20 W.
