Hi, so I followed your advice and I made some measurements using my scope using 2 probes as differential probes and measured the boost cap voltage, and it does seem to be tripping the UV lockout. Before I guess I was making measurements after the UV lockout had already tripped, meaning ofc the boost cap was charged so a bit stupid on my end. On the first capture below, you can see when the UVLO is triggered, the white is high side gate voltage and the purple is the input logic signal to the ir2113. This also explained why my janky workaround of pulsing the logic signal low quickly worked because it seems when the high side mosfet turns off, the inductive kick drags the voltage to ground, allowing the boost cap to be charged again, but after the voltage is back above the UVLO limit, the ir2113 doesn't automatically turn back on. On the second capture below, where white is boost cap voltage and purple is logic input, you can see the boost cap voltage increases after UVLO engages as expected, but the high side gate drive doesn't turn back on until the logic input is pulsed (you have to zoom in a bit as its hard to see, the purple signal is pulsed low very quickly). I'm guessing this is a feature of the ir2113. I don't want to have this workaround, so are there any other mosfet drivers that will re-engage as soon as the voltage is above the limit. Thanks!!
