Lead is not a potent carcinogen, and no one will spontaneously grow a third arm (or be at greater risk of bearing children with additional appendages) as a result of its exposure.
I know, i know... and i know the differences and effect of long time lead exposure.
That stuff is very bad for your, yes.
We should remember, all the fuss about lead was caused by problems on a industrial scale before we knew and cared about what the real dangers of long time exposure are.
We threw that stuff at and in everything, in walls, on roofs, in paint, water lines, industrial waste dumped in the ocean...
That was bad, very bad indeed.
And that was not what my comment was about.
I was speaking about fishermen, hunters, sculpters, historic building maintenence, home soldering... everything were we use lead on a small scale basis, in "big chunks".
There, the occasional lead exposure is no problem as long as you do not eat it, put your head over the smelting pot and take deep breaths and wash your hands afterwards.
Yes, "no problem" is of course the wrong phrase.
But today everything has been proven to be bad for you or give you cancer.
As long as you use some common sense, you will be good.
