How did you determine they are faulty?
What does 4n7K mean for example? And what does the X1, Y1 and "C RUus" mean?
4n7, K, are the value of the capacitor—its capacitance—and the tolerance for that value. "n" means nano and the letter is placed at the position of the decimal point. So 4n7 means 4.7 x 10
-9 and the value is in farads. Another way to write the value would be 4.7nF. K as the tolerance means ±10%. See
http://www.robotoid.com/appnotes/electronics-capacitor-markings.htmlThe part number, on the other hand, typically follows the "two digits, then multiplier" convention based on picofarad units. 4.7nF is equal to 47 + 2 zeros pF, so the part number will contain 472. WKP472KCPEH0KR is the full part number. In this case, "EH0" means that the leads are spaced 12.5mm apart and are 10mm long and 0.8mm in diameter. This is primarily important for automatic insertion machines and you don't have to worry too much about that for manual repairs.
X1 and Y1 are special categories for capacitors that are used across the line voltage: Radio Frequency Interference suppression caps. They are safety ratings to prevent fires, and replacements should also be rated appropriately. "C (Underwriters Laboratories logo) US" means that UL has listed this part and its Canadian counterpart has also. It's a good bet that other nations testing labs have also listed the part but there isn't room to print them all on the package.
Your second cap is very similar, it's a WYO472MCMCD0KR (or "CF0KR", doesn't make much difference). Tolerance class M ±20%.
Question 2: How would I identify cap 3 (smallest one) if I couldn't assume it's a cap from the same manufacturer like in this case? I can't seem to google cap 3
The logo is that of TDK EPCOS. This is a MOV, not a capacitor: part B72207S0271K101. See
https://en.tdk.eu/inf/70/db/var_11/SIOV_Leaded_StandarD.pdfQuestion 3: Where do/would you buy three separate, single capacitors from? The only site I found that carries these capacitors are mouser.de. Are there any alternatives or other recommendations that I should check out?
Digikey, Farnell, Arrow, Jameco, etc
