Author Topic: Ventilation Holes On Soldering Iron  (Read 760 times)
Offline KagordTopic starter
« on: June 26, 2020, 01:14:07 pm »
I'm new at this, I was thinking of taping up the ventilation holes on my soldering iron to make it hotter, as I'm having some trouble melting my lead solder.  Is that a good idea? It has holes that looks like this.
Offline Ysjoelfir
Re: Ventilation Holes On Soldering Iron
« Reply #1 on: June 26, 2020, 01:26:54 pm »
If you have one of those flesh burning wood carving chisels you should think about getting a decent one, instead of doing a hackjob like that ;)
I think those holes are there so that the temperature drop towards the handle is big enough to not burn yourself - well, at least if you know where to grab that thing.
Greetings, Kai \ Ysjoelfir
Offline Benta
« Reply #2 on: June 26, 2020, 01:47:53 pm »
I wonder where they get those soldering operators with asbestos fingers...
Offline Gyro
« Reply #3 on: June 26, 2020, 04:45:40 pm »
You will probably enjoy https://www.eevblog.com/forum/chat/stock-electronic-image-fails/  :)
Best Regards, Chris
Offline Bud
« Reply #4 on: June 26, 2020, 05:20:52 pm »
All of the magic is in the Yellow protection glasses  :P
Offline Zero999
  • 0999
« Reply #5 on: June 26, 2020, 06:28:30 pm »
If you can hold the soldering like that, then it's either broken or not turned on. It should get so hot you'll burn your hand and any tape covering the holes!
