Beginners question on the TL866II Plus ( Firmware V04.02.128 ) and Xgpro V11.90.
Im trying to programme a 5V 16Mhz Arduino ProMini (Clone) over ISCP using a TL866II Plus.
It fails to programme or even read the chip ID, looks like the RST line isn't pulled low enough by the TL866,
and looking at the clone MiniPro board I can see a 1K pull up resistor on RST.
If I removing this 1K resistor then it all works and I can then programme and read the ProMini 328P contents as expected.....
but I would have thought the TL866 would be able to pull a low voltage on the RST line through a 1K resistor?
attached is a screen grab of the RST line with the 1K resistor in circuit, the RST is pulled down to 1.4V ( from 3.6V ... )
and the VCC supplied by the TL866 is 4.5V.
Question... is this what you would expect - or might there be a problem with the TL866???
Thanks
Harry
