Author Topic: Tools to replace relay in humidifier  (Read 740 times)
Offline egmiiiTopic starter
« on: January 21, 2020, 04:59:11 pm »
My Honeywell Truesteam HM512 humidifier threw an error code this week. The troubleshooting manual states "The backup weld monitor input is active when the backup heater relay is off." There are two Tyco T9AS5D12-22 relays controlling the heating coil. My guess is that one of them welded shut. I'd like to take a stab at replacing them for $9 before tossing the unit and spending a $1000 on replacement. Clearing the service code allows the unit to run for a few hours before tripping again, so I can possibly perform some tests with a meter to verify my assumption.
My question is, can someone recommend a good set of tools to complete this repair? Iron, solder type and size, etc. I already have some 0.10" Chemtronics wick to remove the old component. It's been 15 years since I last soldered and my old tools were lost in a move. Things have obviously changed a lot since then and some fresh recommendations would be helpful. The vast selection on the web is overwhelming.
FYI, I've done significant work with 120/240 residential wiring, so I understand the dangers and know how to work safely.
Appreciate your help.
Offline ender4171
Re: Tools to replace relay in humidifier
« Reply #1 on: February 07, 2020, 03:29:59 pm »
Budget?
Replacing a robust through hole component like those relays should be pretty easy with even a basic fixed temp 25 or 40 watt iron you could get from any hardware store.  If you want something for future projects, I would get a full station or at least something like a TS100.
« Last Edit: February 07, 2020, 03:31:44 pm by ender4171 »
Offline CatalinaWOW
« Reply #2 on: February 07, 2020, 05:19:50 pm »
Definitely depends on your future use.  Though with a $1000 opportunity cost your budget should be large.
Personally, for these high heat capacity parts I like the old school Weller soldering guns.  Model numbers like 8200 or 9400.  100/140 W.  $20-50 depending on whether you buy a clone and how much markup your retailer provides.  The kits come with enough solder to finish this project.  Just be careful not to burn the board.
Other options as mentioned in the previous post are fine too.  And they will be more useful for the more general electronic use you may have.  If you foresee doing any SMD work you want to go for the soldering station.
