Author Topic: Tooth paste thermal paste corrosion  (Read 1371 times)
Offline lordvader88Topic starter
« on: July 20, 2019, 05:59:02 am »
I have about 50mL of thermal paste for CPU's, in a needle, but I can't find. So on a 2n3055 I used toothpaste, between the heatsink, and insulator.
It never shorted. There are 2 dark brown rings around the outside, of the insulated circles, where the base and emitter pins emerge. Something has chemically reacted.
Offline Towger
  • Country: ie
Re: Tooth paste thermal paste corrosion
« Reply #1 on: July 20, 2019, 06:14:41 am »
Probably water in the toothpaste.
Zinc oxide creams would probably be a better household substitute, of the type uses on babies bottoms. Eg Sudocrem
https://en.m.wikipedia.org/wiki/Sudocrem
Offline Dabbot
« Reply #2 on: July 20, 2019, 06:27:58 am »
... I used toothpaste, between the heatsink, and insulator.
This is amazing. Did your "toothpaste" taste funny this morning?
« Reply #3 on: July 20, 2019, 06:42:30 am »
I should take a picture, can I upload it directly upload it off my PC? I think I can and did that on here  before
Offline tggzzz
« Reply #4 on: July 20, 2019, 06:55:00 am »
Don't bother. It won't show anything surprising or interesting.
Offline magic
« Reply #5 on: July 20, 2019, 07:04:21 am »
Amateur. You should have known to you mayonnaise.
https://www.hardwaresecrets.com/thermal-compound-roundup-january-2012/5/
Offline Whales
    • Halestrom
« Reply #6 on: July 20, 2019, 07:15:48 am »
I've used toothpaste before.  Two problems:
(1) Water based
(2) Some are gritty
Water is a really good thermal transfer material, but it dries out quickly.  Grit of course spaces things, YMMV may vary depending on the toothpaste.
For actual test results: see DansData.  Excerpt:
[ Specified attachment is not available ]
I'll agree with water-based corrosion, but it will also be residue of soaps and other toothpaste materials.  Clean it off and things should be good.  No thermal paste might be a better long term option than water-based compounds.
« Last Edit: July 20, 2019, 07:18:19 am by Whales »
