Go with one of those 36-40V led arrays, couple it with a CPU heatsink/fan and run it from a multi-cell lithium battery pack. (perhaps two 6S RC lipos in series)
Using 30-40V led arrays gets around the problem of switching/supplying large currents
2000 lumens isn't enough though, you want 8000
http://dx.com/p/prime-100w-8000lm-led-emitter-metal-plate-pure-white-42806
The only issue is charging multi-cell lipo packs. Once you get past 8 cells chargers are harder to find.
Could use two 6S packs in series for operation and parallel for charging i guess.
I just built pretty much the exact thing you just described, a big old flashlight as an "enclosure" some pipe fittings to mount a lens on (screw/unscrew to focus), a CPU heatsink, a 12v boost converter/driver, a pair of 17-45v input 12v output dc-dc converters, a wide variety of RC lipos, a high current lipo LVCO and a 100W LED. Weighs a ton, but if you focus it close and put stuff in front of it it ignites. I assume the DC-DC converter is reasonably efficient as the airflow from the 80mm fan on the CPU cooler is sufficient to keep them cool.
Oh, also, psi, i went through HK and found the best Wh/$ are these
http://www.hobbyking.com/hobbyking/store/__15521__Turnigy_5000mAh_4S1P_14_8v_20C_hardcase_pack.html74Wh, $22.60 = 3.2Wh/$
The ones you linked are 28.86Wh, $20.20, making them 1.45 Wh/$
Sure they're smaller and higher voltage, but the voltage doesn't matter since you're going to have to boost it and CC it to power anything more than a 15W LED, and smaller is only a slight advantage because the rest of the flashlight is freaking huge so the battery doesn't matter much by comparison.
