Author Topic: Isolation for sig gen.  (Read 887 times)
Offline chipssTopic starter
« on: March 03, 2018, 06:55:13 pm »
I am wanting to input a signal into a condenser microphone, it has 60 volts dc to polorize the capsule, I would like to not cream my new SDG2000X, I have read using a dc blocking cap, or 1/1 transformer, what would be the best way to do this? Thanks for your time.
Offline danadak
Re: Isolation for sig gen.
« Reply #1 on: March 03, 2018, 09:20:51 pm »
Thread here -
https://www.eevblog.com/forum/beginners/floating-a-function-generator/
C coupling both connector shell ground and signal would be OK. If you
are real nervous about this take a couple of back to back zeners to protect
output and add some series R between gen/zeners and mic.
Transformer certainly also doable, maybe much higher ratio to keep from
unduly loading condensor. Depends on what you are trying to do, measure
the F response I would posit ?
You could also consider using a pad - https://en.wikipedia.org/wiki/Attenuator_(electronics)
Regards, Dana.
« Last Edit: March 03, 2018, 10:13:43 pm by danadak »
Offline David Hess
  • DavidH
« Reply #2 on: March 04, 2018, 01:51:56 am »
If ground is shared which is usually the case, then a coupling capacitor together with a resistive attenuator are commonly used to do this.
The following users thanked this post: chipss
