I would like to add a frequency counter to my old Trio SG 402 Signal Generator similar to whats been done in this video and hopefully make it a bit more accurate as I'd like to eventually align some old Transistor Radios & CB radio's etc
I have SDR radio on my lap top and it picks up the tone coming from the Sig Gen so I know it works and that the analogue adjustment is slightly out, also
- For some reason my SDR doesn't go below 10mhz and need to know I'm generating a tone at 455khz
- I have found that the Frequency Counter fluctuates / doesn't lock
- The difference between the analogue display and frequency counter increases the further down in frequency I go.
- I then tried using an RF amp set up similar to whats been done in this next video and the counter seem to stabalise and lock around 25mhz - 30mhz with the Sig Gen set to High and full RF gain.
Am I wasting my time trying to attempt this?
Should I look at a better frequency counter than the one I got off AliExpress? Is there an SDR that goes down to 455khz? Is the RF amp a bit of gimmick?
Admittedly I didn't do the greatest job putting everything together i.e. long wires & no coax used, just wanted to see if the amp would make a difference which it did but not as good as what I hoped for.
Trio manual, schematic and external & internal photos & RF amp
https://mega.nz/folder/ZxEWRDYR#SHJYkWr2b_1hyvyD5Bth2QThanks for taking the time to view this
