Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Touch pad for ESP32 ESP32-D0WD touch sensor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Touch pad for ESP32 ESP32-D0WD touch sensor (Read 270 times)
Watth
Regular Contributor
Country:
on:
February 17, 2025, 02:17:06 pm »
Hello EEVblog folks!
I am looking into making a touch pad for an ESP32-D0WD on a PCB.
From what I understand, a simple copper zone can do the trick. But I still have questions:
Are there dimensions restrictions (min or max)? Are there issues with ground plane on the opposite side?
Are external components needed?
Does the pad nee to be conductive, or not (for example covered by solder mask and/or silkscreen) ?
How does the touchpad influence/limit the pin's behavior as a GPIO (if not used as a touch sensor)?
Thanks for reading!
Logged
Because "Matth" was already taken.
PGPG
Frequent Contributor
Country:
Re: Touch pad for ESP32 ESP32-D0WD touch sensor
Reply #1 on:
February 17, 2025, 08:44:31 pm »
I believe if some IC offers touch pad sensing than there have to be AppNote describing it in detail.
Logged
Watth
Watth
Regular Contributor
Country:
Reply #2 on:
February 18, 2025, 10:46:41 am »
You are right, I should have explored this more.
FYI, I found this:
https://docs.espressif.com/projects/esp-hardware-design-guidelines/en/latest/esp32/pcb-layout-design.html#touch-sensor
Logged
xvr
Country:
Reply #3 on:
February 18, 2025, 11:07:37 am »
More info:
https://github.com/espressif/esp-iot-solution/blob/release/v1.0/documents/touch_pad_solution/touch_sensor_design_en.md
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/cap_touch_sens.html
Logged
Watth
Watth
Regular Contributor
Country:
Reply #4 on:
February 18, 2025, 01:20:45 pm »
Hey xvr,
In the meantime, I found the first link you provided, I was about to update my latest reply!
As for the second link, it is about the software part, but I'll keep it in my bookmarks.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
