Ah, yeah, the slot in the ground is a big no-no for high speed signals like this. It can act as an impedance jump, and as an antenna.
Also your top plane is far too close to the diff pair, resulting in a "Dual co-planar waveguide with ground" with a different impedance to what you calculated. Rule of thumb is the top plane clearance should be at least 5x the thickness of the dielectric, to use the usual diff pair over ground calculation. In your case that would be 50mil.
And plane stitching - min every 10mm along the diff pair. And along the edges of every ground plane island.
It might not seem like a big deal, but could be the difference between working or not.
I've seen this happen with USB - the changing the ground spacing and stitching was the difference between passing or not passing compliance testing.
Asking for impedance control from the fabricator means they are more careful in controlling the thickness of the dielectric layer in question, and more picky about which material they use. Otherwise everything is slapped together, and as long as the whole stackup meets the the tolerances it'll get shipped to you. So any time you have a controlled impedance you need to tell the fabricator.
