i) 0-15 seconds: no hum.
ii) 15-20 seconds: hum quickly builds up to quite high levels.
iii) 20-35 seconds: the hum gradually subsides to zero level (not audible anymore). I wish it stayed like that forever.
iv) 35-45 seconds: the hum slightly builds up again and stabilizes at a low but well audible level (~7mV pk-pk at speaker terminals, see first scope screen-shot in the OP).
I'd like to prevent iv)
Hi, Andreax1985. This sequence of events is perfectly normal and to be expected in all tube amplifiers to one degree or another. It happens in mine except for iv). That part doesn't happen and I can tell you what causes it and what I did to get rid of it.
The waveforms you posted are to be expected for just the reasons that Soldar said. The rectifier bridge and the two halves of the power transformer HV winding are not exactly matched. But that mismatch is not the cause of your audible 100 Hz hum. Mismatches in the output tubes and the output transformer are. The output tubes you have may be sold to you as a matched pair but they are definitely not perfectly matched at all bias levels, plate currents or voltages. There will be small differences. Also the two sides of the output transformer primary winding will have some small mismatch, possibly by half a turn or because one side is a layer or two nearer to the core or whatever. So even if you unplug P24 and short both inputs to ground, the two tubes will conduct slightly differing zero-signal currents. Those two currents will have 100 Hz components and the slight imbalance of the OT will propagate them to the speaker. With the circuit that you have there is nothing you can do about that.
i) happens because the outputs tubes have not warmed up yet and are drawing no B+ current
ii) happens because they are warming at different uncontrolled rates and pulling largely different B+ currents
iii) happens as the two tubes slowly approach as much balance as they can
iv) happens as the two tubes settle to their final operating point values but even so are not really well balanced.
In my amp, I have individually-adjustable bias voltages for each of the four output tubes in my stereo amp. By fine tweaks of these I can balance each pair of tubes so that the 120 Hz (in North Am.) and most harmonics nearly perfectly cancel out in the primary of the OT and they are not heard in the speaker. There is some thermal noise and higher harmonics left but that is it. It is about 1 mV RMS total. My preamp filaments are also DC and the B+ for them are regulated so when the volume is full up its tough to hear anything even when I bend down and put my ear to the speaker cone.
What you need to do is to separate the bias of your two output tubes and make them adjustable.
You can do this by changing R8 from 120 Ohms for the both cathodes to two resistors, one for each cathode. They should be 240 Ohms but with some room for adjustment. Each must be bypassed with a cap about the same size as whats there, so you can keep C21 for one of them, just get another. One of the two resistors should be composed of a 200 Ohm resistor with a 100 Ohm wire-wound pot in series. When you first test it, put that pot at mid-position. Then, with the amp fully warmed up, adjust it for minimum hum in the speaker. BTW, when you wire the pot, short the wiper to the otherwise unused end of it so that if the wiper fails the pot will not go open but just to its max value. The amp will still work but with lots of hum.
I guarantee this will work.
